They are having a discussion over at the Antique Radio forum about Chinese Capacitor testers, of which I just ordered a couple. It was pointed out that while they do basic quick and dirty tests of capacitor they don't really "test" as if the capacitors where in an active circuit, and they where of questionable value testing capacitors used in tube type equipment. They started to mention vintage condenser testers, which do test a condenser in a simulated circuit. I have never used condenser as a search term, and here I found all kind of condenser testers. I was told the Heathkit testers where good ones. I purchased a very clean and tested Heathkit Model C-3 it is considered one of the good ones and very simple to operate. Interestingly the the units left side see the knob that says "power Factor" that is what they used to call ESR. It uses a 1626 triode, and a 1629 "magic eye" tube. It also tests resistors, a secondary function for me because I have other things that can test them. The prices on these instruments are very reasonable.
