I have ordered a Pioneer PLX-1000 direct drive turntable.....
Status
Not open for further replies.
Actually, that line is lifted directly from Technics. Due to noise and mechanical issues there's a practical limit to measuring with a cartridge.
Actually, the Panasonic specs for the Technics, which you can follow here, are given in three different internationally accepted standards. Yup! The whole shenanigan looks 'lifted' indeed.
From the MKII user manual.
As far as I can tell, it refers to the rumble measurements right under the W&F specs. I don't see a reason for W&F to be affected by noise. Do you suppose this line was actually 'lifted' from the Technics SM but, by mistake, from the wrong context? That would be really weird...
That's just it - I disagree. Like I said, I don't see how somebody can view this in a vacuum. Pioneer clearly wants the customer to consider this a rebadged Technics, or else they wouldn't have made it cosmetically identical down to the last detail.
It isn't.
Certainly, it's very similar and that can't be an accident but we have to remember that this is a "pro audio" turntable, in effect a tool of the trade so it can be considered a plus if its control layout is all but identical to the turntable(s) most DJs are used to.
I can understand "who cares if a Grado doesn't work with it" in a vacuum, but when something is a reproduction of Table X, and Table X does something better, then I begin to wonder where else corners were cut.
It doesn't.
As I mentioned before, the Grado Hum Database contains reports of problems with some SL-12XX turntables. So, I think it's fair to say that Grados cause problems with some 1200s and, really, that's all we can say relative to the PLX-1000.
John
There's an asterisk at the end of the 0.01% WRMS line, which is what the note refers too. Electrical noise, record noise floor, record eccentricity, and perhaps more importantly as I've recently read in an AES paper, the resonance of the arm/cartridge system influence the measurement of flutter.
When I get my FL-180A at the end of the week I'll start doing some experiments, as I've a table Technics spec'd at 0.015% JIS C5521.
Here's the SL-M3:
You are right, I just noticed the asterisk on the first W&F measurement saying 0.01% WRMS. Excuse me for still being kinda suspicious and flummoxed by the exact bad grammar, that appears to had been copied straight out of the Technics manual, right into the Pioneer DJ site, stating the exact same parameters as the 'competition' in the most relaxed measurement method of W&F, in contradiction to the official site's publications, that are in synch with the mfgr. For some reason it just doesn't encourage too much confidence in the released data. Does it?
BTW, good luck with the Kenny. It will be interesting to see if you can verify the Technics specs and how the Kenny is in comparison.
Keep us posted please.
Wayner,
You're still offended? Some further explanation for your sensibilities:
A couple of days ago you posted this:
Just to refresh people's memories, or to let new readers to this (getting old) thread catch up, my review was not based on country of origin, but rather on performance and the expectations I had for the machine.
If you do not mind that the antiskate is inadequate, this table is for you.
If you do not mind that the stock headshell will only allow a Stevenson alignment, this table is for you.
If you do not mind that your MI cartridge hums from poor shielding, this table is for you.
If you do not mind that the stated specs and claims of a "more powerful motor" then the Technics SL1200MKII do not live up, then this table is for you.
I did not have to fix my Technics SL1200MKII's antiskate.
I have my Technics SL1200MKII in a Lofgren B alignment with its stock headshell
I can run a Grado Gold with it and not have any hum issues.
I can even brush clean my records with the motor running, with no problems.
The very definition of quality is delivering what the customer expects. The Pioneer did not. I wanted it to, it did not want to.
'ner
Just to refresh your memory, in March you posted this:
"I have finished 1 LP while I have been typing this, Thomas Dolby's "The Aliens Ate My Buick" and I felt the sound stage and musical content was as the Technics, but I will do some heavy duty listening later."
And this:
"BTW, yeah, its certainly the top of the heap for a $700 table. I would not waste my money on an AT-LP120 when you can have this one, unfortunately, it a bit more, but I think its worth it."
Change your mind or just wanted to point out shortcomings?
Previously you said:
"Of all the tables that I have (or have had) the Technics SL1200MKII is a very dynamic, emotional music machine. It needs to have a couple of tweaks done to it, it needs to have the right cartridge paired with it and it will produce an enormous sound stage. I also have the Technics SL-Q2 and it is not in the same presence as the 1200. All of course, IMHO."
I realize time was limited, but you didn't give the Pioneer anywhere near the same consideration. You wouldn't even try another headshell. That's why I said what I said.
neo
The whole spec wars thing was a bit ridiculous back in the day because the shifting standards and reaching a point where the specs didn't have anything to do with real world record playback anymore. For example Thorens TD-160 had 0.06% w&f spec in Europe (DIN), but according to the audio-heritage.jp site the JIS spec was 0.03% - makes one wonder if they came up with the JIS standards originally to make Japanese tables look superior to foreign competition... in any case the weighing seems a lot more forgiving than DIN for example.
Personally I haven´t found any difference in skating force worth mentioning between unmodulated grooves, test tones and different music. I consider it to be about the same for all practical purposes.
As for W&F using a test record it will be very difficult to have a lower figure than 0,04% as test records inherently normally aren´t better.
And as been mentioned W&F are complex as the results also are depending on tonearm resonance and record warps. If we would get a figure of e.g. o,07% we have to look at possible causes for that figure, there is no certainty it will depend on platter speed variations.
...As I mentioned before, the Grado Hum Database contains reports of problems with some SL-12XX turntables. So, I think it's fair to say that Grados cause problems with some 1200s and, really, that's all we can say relative to the PLX-1000.
John
I'd be a little suspicious of the hum database. Hum can come from a number of things in the HIFi setup, so attributing everything to the turntable when the cartridge is unshielded may not give an accurate picture unless all other likely causes are checked first.
Lets take a look at some facts about using the blank disc to set anti-skate:
1. I have records that I had bought as a teenager that show no signs of inner or outer groove wall damage, physically speaking, and no evidence of damage is heard when the record is played and many of the records have been played hundreds of times.
2. My DIY, calibrated VU meters show even channel distribution thru the entire side of the LP.
3. Viewing the stylus behavior in the record groove offers no signs of alignment problems. The cantilever is centered and "square to the world" as it travels the record grooves.
4. I examine my stylus about 3 to 4 times a year. The stylus wear is symmetrical.
5. Listening to music in my near field environment, the sound stage is centered, deep and wide.
There simply is no evidence that using a blank disc over-compensates for the skating effect. I have decades of proof.
I have. When I've compared the results of setting my antiskate with a test records to the point where there is no longer any distortion and then tried a blank record, the arm never remains in one place but always pulls to one side. Granted, the Pro-Ject "three notches" approach doesn't offer the range of adjustment a spring/dial does, but it does tell me the test record approach is probably the better one.
Wayner, seriously, these are not "facts about using the blank disc to set anti-skate" they're your personal observations. You seem to take great pride in reminding us over and over again that you're "in engineering" so surely you must see that you recounting your personal observations does not make for "facts." I can say the moon looks like it's made out of swiss cheese. It doesn't make it so! Unless you actually measured the forces and provided numeric comparisons, these are not facts.
Of course, maybe Harry Weisfeld is right and antiskate is irrelevant.
Wayner,
And this:
neo
Indeed. Lack of consistency has been my main issue with this whole endeavor as well. first the antiskate was not right, but still usable. Then it wasn't any good at all. Now it's just inadequate. Then this morning while checking for something else in the thread I noticed the following contradiction:
On March 5, Wayner stated he was barely able to get his Technics into an IEC Baerwald:
I do have my Technics SL1200MKII in an IEC Baerwald, I think there was next to no room to go, but it is there.
This first statement mirrors what I often see around the net, that some folks are able to barely achieve a Baerwald with the stock Technics headshell. It's easier for those who attempt a DIN version than an IEC, but depending on the cartridge, it's doable.
Yet now in September, he says he has his Technics in a Löfgren B alignment, which by its nature requires a longer overhang than IEC Baerwald, a.k.a Löfgren A) :
And in fact, he says you can use any alignment you want!
You can put the Technics is any alignment you want.
What happened from March to September, did his headshells expand over the summer?
That is not what I meant. I meant measuring the actual friction force provided by the grooves. I didn´t mention any blank record. I see no particular difference in friction force if it´s an umodulated groove, a groove with sine tones or a groove with nornal music.
It sure isn´t irrelevant for the stylus, as the inner radius will have a much higher normal force.
Edit: As for the blank record setting. It can of course vary from stylus tip to stylus tip, that is a problem. But for most tips it´s probably rather OK, but the friction force provided by a 'good' tip will be lower than if the tip is in a groove, as then the normal forces will be higher.
Too many people in this thread are just enjoying fussing instead of educating in my most humble opinion.
700 dollars is a lot of money
I bought a plx1000 and could never get it to sound proper
later i learned the arm bearing and anti skate were defected
Fortunately i received a full refund, got in under the deadline
with the money just for the pioneer alone i bought an Audio Technica AT-LP1240 and a DL-110 and audioquest cables
I've never been happier
Money better spent in my case without a doubt
I've owned the Pioneer and now own its competitor.
My vote is for the AT-LP1240 hands down if anyone is looking for a new SL1200 clone. The PLX1000 is over priced and comes from the factory with problems which the 1240 does not.
Yet now in September, he says he has his Technics in a Löfgren B alignment, which by its nature requires a longer overhang than IEC Baerwald, a.k.a Löfgren A) :And in fact, he says you can use any alignment you want!What happened from March to September, did his headshells expand over the summer?
Garven...do you have anything CONSTRUCTIVE to offer with your comments, or are you just here to disagree with anything/everything from anybody/everybody?...this isn't the Hoffman forum.
Status
