I need a a little help hooking up an.....
mrjbq
Bose forum Moderator
ADC equalizer I picked up this morning. I have a couple receivers. A Marantz 2250b and a Yamaha CR-1040. So how do I connect this to either receiver?
TIA.
In either a tape loop or a processor loop. For example, tape out to EQ in, EQ out to tape in, leave the tape monitor switched on to have the EQ in circuit, off to take it out. Processor loops work similarly, but I don't know if either of those receivers has one.
What are "processer loops"? I have have "main in, main out", is that what you are referring to? There are no "jumpers" on the Marantz main in, main out jacks, however
Use the tape loop. Processor loops are dedicated I/O for things like EQs, noise reduction, reverbs, companders, etc.
OK, I connected tape out on ADC to Tape In on Marantz and vice versa, then push tape monitor 1 on Marantz. But I get nothing, the Marantz plays normally. Help, please.
Do you have the ADC turned on? That the Marantz plays anything shows that you are putting info through, but if the EQ isn't on, then you won't get any change in the sound.
Don't use "TAPE IN/OUT" on the EQ. Those are for an additional tape deck. Use the ADC's main in/out jacks to the marantz tape in/out jacks.
