I own a Gt-750 and I must say it a awesome turntable with al of its parts, except the base which was kinda cheap, so I made a complimentary one.
I've used 5 18mm birch wood multiplex plates, machined them using the original base as template.
Also I going to make a separate cabinet for the power supply, and I changed the original transformer 100v with a 220V with a output of 30-35V, works perfect, so there is no need for a step down transformer.
Next step would be, fit the en-longed cables into the base machined tunnels and glue the plates together, make the cabinet for the power supply, veneer it all and reassemble.
So if you don't have the money or want too spend that much on a 2000, you don't have too, the 750 is a good enough table, my bet is you wouldn't here the difference when played under the same conditions.
But then again it is nice to own such....:yes:
