HDMI cable out from phone to receiver?
I guess what I am wondering is if I go out usb from phone to a some brand of external box and from that output either digital coax out or optical. to my receiver will that device affect anything or will it act as mostly a pass thru device. I want to know what My internal dac is capable of not the device what's in front of it.
I hope you understand what I mean.
I do, and have been to this rodeo a few times.
https://www.ebay.com/itm/XDUOO-XQ-5...122434?hash=item3b3a5b25c2:g:oLMAAOSwlXddm1PO
I ran many different DAP's (Digital audio players) over the years, have a few threads up on them now. I have converted the Zune and iPod to SSD's, and have been playing with different cell phones from the iPhone 5 to the X.
I don't know how the path is set up on that AVR. As @swechsler stated above, your other inputs may be all digital and not able to access the DAC in the actual receiver.
you may want to check the manual.
I know the coaxial and the optical are digital inputs, I'd look into the xDuoo myself. I just ordered one just now to try it out. I can let you know when it arrives if its any good.
The reason I keep suggesting the BLT2 and xDuoo is the fact that they do not color the sound stage, the BLT2 sends a strong signal as well, you get good output with that device.
Now if you ONLY want to use the DAC in your receiver, I would look at the manual and see what inputs you have that will allow you to access the onboard DAC. Than use those inputs.
For me I use dedicated players and my phone, I currently am using the BLT2 with the optical output, I have not tired the coaxial but would assume it would sound good.
Another question for you,
what service are you using to stream? Spotify, or are you using Hi-Res files like FLAC or WAV?
