Considering that it just did pass the significant other test, I beg to differ.That's not going to pass the significant other test!
MFR and model number, please?
Every FM station comes in chrystal clear, stereo and mono.
I get stations I didn't used to get at all with my 6ft long dipole T style antenna.
Very impressed.
And for a whole 20 dollars. Can't beat it.View attachment 1449541
I believe RCA used to sell an "S" shaped folded dipole like that as an omni, and Radio Shack marketed them under their Archer brand. The only potential problem with that type is multipath interference.
I dont dispute that, but it is working 75 times better than my other dipoles and as I was testing different locations trying to find the sweet spot, I found that it did not matter where is was. Every station pegged with static free audio regardless of where it was.Not to rain on your parade, but it's simply a folded dipole bent back on itself in order to yield (supposedly) an omnidirectional pattern. Whatever you do, don't move it, because even a slight relocation might significantly degrade your results.
In other words, the performance of indoor VHF and UHF antennas is often highly dependent on location and surrounding objects.
What is not to accept? It is out of the way, clean, tidy, functional....I’m glad it works for you but that doesn’t even pass MOAF.
My Own Acceptance Factor. (copyright pending)
I can't judge how far it is above the metal rack
My original intent was to put it In the attic thinking that it needed to be up there in order to perform at its best. I hooked it up temporarily just to make sure it worked as seen in the pic after playing around with a few different locations. It worked so well, I just left it there. I may bring it up to the attic at some point.I've had the same antenna for a couple years, mounted in the attic of my garage. It does a pretty good job.
