gvocale
I am trying to install an IBBA board into a Sherwood S-5000 II
I am using the following schematic, posted here on AK in another thread.
If I measure resistance between the DC balance pot and ground, with the IBBA not plugged into the amp, by turning the potentiometer I swing between 15k ohms and 25k ohms. It makes sense to me, as it is a 15k resistor + 10k bias potentiometer.
I connect the IBBA ground to the chassis ground, and the header supply to the negative rectifier source. Now I measure a swing between 6k ohms and 7k ohms.
What is happening? Why my resistance is off?
My IBBA at A / B / C / D gives me just -11, down from -30v at the header supply, rather then the 18~21.5v I would have got if the resistance would have measured 15k to 25k.
