This is actually not exclusively Sansui related nor is the cause stuck in protect. The issue was that at powerup the Sansui AU-D11 amp on my workbench took ages (OK, several minutes) to switch on its output relays even though the amp's outputs were at zero. The cause was the voltage on C4 not rising above 1 V whereas the trigger point is at 3 V. It seems that the HA12002 IC has a design flaw that causes some sort of latchup condition that prevents C4 from charging above that 1 V. The kludge I made was adding an emitter follower between C4 and pin#8, powered from pin#7, the chip's BIAS voltage:
A BC547B or any other suitable universal NPN transistor overrides the latchup like a charm:
The HA12002 already was replaced in vain and I could not find any other issue preventing C4 to fully charge.
