GoldSounds
So I picked up a pair of JBL C53 Libras over the weekend. Driver complement is LE20 tweeters and LE14A woofers with LX-8 crossovers. Good news is that all the drivers work. However, the Lansaloy surrounds on the woofers has gotten still with age. I have read (particularly on the Lansing Heritage boards) that you can apply a small amount of DOT 3 brake fluid to the surrounds to at least temporarily make them more compliant. I have also heard many complaints saying that this may/will stain the white cones. I am not sure, but I believe that the surrounds may have been replaced or treated before; I can see some glue or other coloration but I'm not sure if it's original or not (see pictures).
My questions is: what are the risks and benefits of using the DOT3 (or refoaming) on the surrounds? I am not sure what to do because on the one hand, brake fluid is cheap, simple and keeps the surround original (and as such possibly retains resale value). On the other hand, refoaming is more permanent and will at least restore xmax. However, I have heard that this may change it's Fs, in addition to changing the driver's appearance and possibly lowering it's resale value. A third option is to do a full recone, which is apparently the only solution that Harman International endorses, but seems to be a waste of a perfectly good cone and spider. Ideally, if there is some magic solution that I can apply that will perminently restore them (think that AR/KLH woofer doping stuff), I'd gladly seek it out.
Anyone who's had experience with any of the above procedures, please advise.
Pics of underside of LE14A driver:
