Homer4beer
Well-Known Member
Hi guys,
I managed to fix this amp and am now trying to adjust the bias. I am measuring the voltage across the two legs as per the service manual.
I've attempted to adjust the bias now. For the bias for AB, set from cold, I can set both variable resistors to measure 0.4mV < 1 min.
For the class AB measurement I'm testing from cold across the two outer legs of 3335. I'm adjusting to get 0.3mV - 0.4mV at 1 minute. Then I turn off and wait for 5 mins (to make sure I'm starting from cold again) and then swap to 3336, repeat. Same process for 3337 and 3338.
I'm going off my multimeter for the readings.
When I leave the amp on for 30 mins I am only reading 10mV when the manual says it should be 18mV+-3mV. Odd.
Question....when making the Class A measurement do I turn the amp off, then back on again in class A then measure? Do I wait for 10 secs or so before turning back on? Longer? The service manual does not say to turn the amp off, just "Next, switch to class A operation." Now when you switch between class A and AB, going by the manual, you are supposed to turn the amp off first.
With the amp on for an hour if I turn it off, wait for 15 secs, turn it on and set the class A bias I can get it to get into the 65mV - 70mV range at 30 secs. It then climbs to 85 ish then drops to 80 - 82 after another 30 mins? The manual says it should go above 90 and then fall to stabilize at 90mV +- 5mV
What on is going on? Both the Class AB and class A voltages are not stabilizing to what they are supposed ot.
I can only assume I'm doing something wrong?
Thanks guys
Pics of what I'm connecting to and the manual.
Thanks guys
