Andrew Jones favors concentric drivers in some of the Elac models he designed. I have them in my UB5 speakers.
Q1. What are the main differences between the Uni-Fi and the Debut Series?
A1. The Uni-Fi is intended as a step up in performance compared to the Debut series. As such it is both a three way system and incorporates our concentric driver technology, named Uni-Fi. In addition, as a three way, the drivers can be better optimized for their particular frequency range and so the cone materials are chosen for this purpose (aluminum for the bass and midrange drivers, cloth dome for the tweeter).
Q2. What are the main advantages of a concentric driver?
A2. First, what is a concentric driver? In general, it is a driver where the tweeter and bass/midrange driver have been combined into one compound unit. The tweeter is mounted at the apex of the cone, sitting directly on top of the bass driver pole piece, where the dust-cap would normally be found. The result of this is to match the off-axis characteristics of both drivers so that the sound is more even across the frequency range. The imaging will then be better, the sound character will be more consistent throughout the listening area, and will be less influenced by the acoustics of the listening space.
Q3. What are the main advantages of a 3-Way speaker vs. a 2-Way speakers?
A3. The principal advantage is that the drivers are operating over a narrower frequency range. As a result they can be better optimized for their intended purpose. In particular, the bass/midrange driver is no longer required to reproduce both bass ad mid frequencies simultaneously. This reduces the total amount of power going into each driver, reduces distortion and produces a clearer midrange and more dynamic bass performance.
Q4. What are the advantages of the aluminum drivers compared to other materials?
A4. The best choice of cone materials is governed by the intended application. Not all materials are ideal for all applications. The advantage of aluminum for the bass driver is its good balance between performance and cost. It is easily formed, consistent in production and has a good ratio of stiffness to weight. More exotic materials have very little further advantage in this size of bass driver. With the midrange driver, we generally find ourselves working with materials that are not rigid over their operating range. For example in the Debut speaker range, we use Aramid fiber. This gives us the capability of carefully controlling the cone flexing to get the best performance. This difficulty in design is somewhat ameliorated by having a three way speaker, and also now allows us to change to an approach that eliminates flexing within the operating range. Aluminum, as optimized in the Uni-Fi midrange, has its first flexure mode at a high 8kHz which results in excellent performance.
UB5
