On another note I'd say if the actual voice coils are fried on the Audax's that they could probably be repaired.
Hello AK,
First time poster here. I'm trying to bring a set of TLS 80 Mark II's back to life. It looks to me based on going through this thread that someone has changed the original crossovers. What's confusing is the board used says IMF on it, but it doesn't look like the crossovers that I was able to find here. I've attached pictures of the crossover--its in two parts. Can anyone confirm that these are or are not the original crossovers for this version of the TLS 80 Mark II. As I said, I would like to restore these to original and have purchased the TLS 80 Mark II recap kit from Falcon Acoustics. I found a schematic for the crossover in the thread, but it is missing the specifications for the Inductors: L1 (Pink Dot), L2 (Green Dot) L3 (Yellow Dot) L4 (Peach? Dot).
Can anyone DM or post here the specifications for the inductors or post here. I could not find these in the thread.
Does anyone know of a source for replacement inductors that will fit the original schematic PCB board? I'm reposting the schematic and crossover that I think is the correct one. Thanks to the original shooter.
jon.Hi ThanaView attachment 2107465 View attachment 2107467 jon.
Just to point out that I don't think you have the correct crossover diagram. Please see what I believe is the correct version and that my speakers are within a few hundred of yours. Look closely at the serial number.
I have also ordered a replacement set of capacitors from Falcon acoustics and hope to be replacing the old ones too.
In the meantime does anyone happen to know DEFINITIVELY what the impedance of the HF1300 and HF2000 are supposed to be for the IMF TLS80 mk2 with the KEF and Celstion drivers as indicated, ie NOT the Mk2A which used IMF's own drivers madly ELAC.
According to Jerry at Falcon they are both 8 ohms but at least one "reliable" internet source suggests 16 ohm for theHF1300s.
Best Nick.
