To my ears, the crossover with the B110 was not correct, resulting in a peaky high-midrange / low-treble, after finding 8 ohm 1300's the RSPM's sounded like I remembered from 1978, remarkably neutral for a speaker from the 70'sPeter, do the highs sound a bit hot to you with the 4ohm? In what way did the 8ohm sound better?
Hi, the 2 Hf1300 on ebay are 15-16 ohm not exactly the right one? Normally the 4 ohm version have black plastics cup in the back, compare to the other version who has the same metal dome like the HF 2000 , same like the picture on ebay.
Honestly I fathom to comprehend the above story. In no way would I be leaving any unattended box full of drivers laying around. All my spare drivers are either under out bed while all the tweeters are in our walk-in robe.
All I can say is.......................UNBELIEVABLE !
You could look for HF1300 Mk 2's, I think all of these are 8 ohm, they were sold to the DIY market in the early 80's and come up every now and then on ebay or other online platforms. I found a NOS pair some time again, I keep them as spares, the 1300's are rather fragile.
good luck with your search, kind regards, Peter
View attachment 2225488 View attachment 2225490 View attachment 2225491
Hi, I probably have 2 for you,but let me verify tomorrow, I have 2 pairs from Ditton 25 first generation maybe they are 8 ohm.Yvan.
Hi Slapshot, all of my Ditton 25 tweeters HF 1300 are 15 ohm, I have one from BBC ls5/1a and it is a 15 ohm. , seems the 8 ohm are not used very often?best regards, Yvan.
Hi Slapshot, I can sell you 2 hf 1300 15ohm both for $50 so you can order the 8 ohm coil from ebay,that should fix your problem. Best regards
Hi Slapshot, the seller on ebay ninomusic sell these, you can order two at the same time.He sell two type of coil ,one is just the coil (arround 18$)so you have to remove the old coil from the original cone and install this new coil, you probably have to made a template to center the new coil. The other seems like complete with the coil but different cone material and have a dome shape, I don't no if the sound will be altered compare to original price arround 35-40$.Myself I will take just the coil to keep the same voicing.Yvan.
