c-atle-79bay
Welcome Roger. These are wonderful speakers indeed. Is your preamp ES TA-E9000? I"m considering that pre along with the sony TA-n9000es amp right now. Any chance you also had that at one time?
But won't part with the speakers!
Roger
That and altec valencias are not a simple swap out kind of speaker
Any tips for songs with really low impactful bass? Any genre appreciated.
Also have added an ESS Heil Elite. Sounds great.
I've just tied in the Heil's and set the level on the external crossovers and cut at 1K vs 5k. I believe the dial on the back is level control and not a brilliance/presence control.
Yes, parallel, per ESS instructions, even for new heils. Don't know how much impedance hit they give, but so far no issues on any of my amps.
In my case I'm still running all the IMF drivers but have dialed down the HF to it's lowest setting. Too high and weird effects start happening, as it is more like I have ribbons back in the mix.
The SM's had been delivered to me with corner damage. I didn't do the resto on them but the guy who did is a master at furniture restorations. Didn't re-veneer them as i wanted to keep them original venner from factory. I recaped the crossovers and the last owner re did the midrange surrounds. They come up looking like new. They have been french polished too.
Yeah he did.Well, they certainly did a fantastic job on the repair. It looks great! I can't even tell.
Nice work on the speakers, sounds like you know what you're doing. That's always nice to see. I'm interested to hear about a comparison between the Studio Monitor and the TLS 50 since they are essentially the same, one is just a newer version and is a 3-way instead of a 4-way.
Good Morning,
The surround of the Peerless KO40 is not original, and actually I don't know if it even a Peerless. Note that the KEF SP1039 B200 bass speakers in the cabinet sometimes will hang downwards. This type of KEF has a big magnet, a wide very flexible roll, and somtimes the voicecoil wil scrath due to the misallignment of the cone. Further the switches on the back will be often dirty and need to be cleaned. The Cole supertweeter has normally a cap over it. Be carefully with them, they often get broken.
Best regards, Fred
Hi Fred,
I'm not aware of any IMF models using the Peerless KO40MRF midrange driver. I used to think so but, in all of the research I've done I haven't found one model that uses it. Do you happen to know a model that did? The original TLS 50 and Studio models use an EMI midrange driver, and then later switched to an Elac midrange driver. The EMI looks similar to the Peerless, but certainly isn't the same unit.
