I tried to attach the brochure here in this thread for all to read paragraph 3 downward, but the site won't allow me because it says it's already linked on the other thread. I'll try a web link instead at bottom of post here, if that works, I hope.
If going down to very bottom of spec sheet you will also notice the model you are referring to (Compact II) is a 2-way design, and thus, of course has no midrange tube, only a general port for the cabinet. That model's woofer also covers it's midrange and only extends to 35 Hz, not 30 Hz as in the model we are discussing -the Super Compact (series I and II).
I believe you are mixing the two models...please reread my earlier posts about vertical foam strips constructed into vertical channel to isolate the midrange and another seperate channel to isolate the woofer. They may have resistive-load line tuned the reflex cabinet design for the woofer in isolation with also seperately isolating a down-vertical and out-forward bottom channel for the midrange seperately. A t-line chamber cavity does not have to be constructed of wood on all 4 sides - different isolating materials can be use to establish the transmission line - the resistive loading is important.
But, again...IMF prints the Super Compact "mid range is ISOLATED in it's own short transmission line". They can use one vented bottom port for both the individually isolated bass-reflex woofer combined with an individually isolated tuned t-line for the midrange -it's what the entire cavity looks like that's important from the top rear back wall down to bottom and out. If tuned properly and resitive-loaded -both low & mid frequency drivers can exit the same front vent if they are properly isolated apart from each other from path origin to final venting out. That "tunnel" can be made with foam vertical channels or other materials.
If someone has a factory-original Super Compact that they gutted to bare bones, we would know the answer, and then need not speculate on the actual construction of this midrange t-line. Probably someone has done that beyond replacing drivers & crossovers. IMF printed this information, not me, but some are wondering about the actual physical configuration of that mid-range transmission line.
I'll try posting a web link here for that brochure, so folks can read IMF's information, see the bottom speaker diagram and very bottom page specs, along with 3rd paragraph from top discussion of the Super Compact midrange t-line. Hope this link works.
http://p10hifi.net/planet10/IMF_compact_brochure.pdf
I think the great minds at IMF were careful in their reknown SC design -it was their best seller. The discussion may want to be not about IF a midrange t-line DOES exist, taking IMF's word as truth, but rather - as originally asked - how is it constructed, and what does it look like internally, for IMF's exact meaning of this t-line physically.
