Digging through the archives I found an old post from roggom. Can someone confirm this procedure for me?
"Not sure of what amp you are modding, This will be some extensive soldering as the 6eu7 is completely wired different than the 12ax7.
Download both datasheets here and have them for a reference.
http://tubedata.itchurch.org/sheets11.html
One more thing, the 6eu7 is 6.3 heaters and the 12ax7 is 12.6 you will be running the new tubes with the filaments in parallel.
Since pin 3 is blank we will start there.
Desolder pin 4 wire and solder it to pin 3
take pin 2 wire and solder in pin 4
take pin 5 wire and solder in pin 2
Make a jumper from pin 4 to pin 5
desolder pin 9 wire and hold it off to the side
take pin 1 wire and solder it to pin 9
desolder pin 6 wire and solder it to pin 1
desolder pin 7 wire and solder to pin 6
desolder pin 8 wire and solder to pin 7
take pin 9 wire ( that was off to the side) and solder to pin 8.
Now you can roll in 12ax7 12at7 5965 etc."
Sent from my
