frankj389
Hi,
Recently, I acquired a pair of Acoustic Research AR-5's and have come to learn that the woofers are not original (also my cat fell and placed a large hole in the woofer surround with his foot), so I need to get them replaced. I've been scouring eBay for a while now, and I cannot seem to find a listing for the exact AR-5 woofer. I've done some looking around and have seen that the p/n for these woofers should be #200004-3. Specifically, in this thread: https://community.classicspeakerpages.net/topic/777-ar-timeline-dating/ , someone suggests that
"the 1970-version AR-2ax actually did not use the same woofer as the AR-5. There were some subtle differences in the cones and voice coils between the two and the crossover frequencies, of course, were different. The AR-2ax woofer was #200004-2 and the AR-5 (and LST/2) had #200004-3 (later #1200004-2 and -3). By the mid-80s, however, all the 10-inch woofers for the AR-2ax, AR-5, AR-8, AR-12 and AR-LST/2 were all the same, and all by this time had the ceramic magnet structures."
Going off of this, should it be fine if I got a set of woofers from a pair of AR-14's that have the p/n #200004-2? This is the listing I'm considering:https://www.ebay.com/itm/265405173657?hash=item3dcb618f99:g:NZoAAOSweeBhkRfb
Thanks.
Thanks.
