I finally got my Infinity Crescendo CS-3007s back together today, and thought I'd share some pictures.
The first one concerns the midrange, and is an excellent reminder of why I don't use generic foams. Actually, I bought a surround kit from an eBay seller who said the kit was specifically for the CS-3007s. When I trial fitted the midrange surrounds though, they looked a lot smaller than what was originally fitted. I contacted both Rick Cobb and Tom at myaudioaddiction, and gave them the ABCD measurements. Rick didn't have anything that matched, but Tom did. The picture below shows the eBay foams on the right, and the foams I got from Tom on the left (trial fitted). Luckily, I was able to send the "kit" back to the eBay seller for a full refund.
If you prefer to shim your woofers, the dust caps on these can easily be removed. Just don't bite or cut your fingernails for a week, and they are an excellent tool for lifting the dustcap up. Once started, a yellow spreader the kind used for auto body filler can be used to remove it completely.
Here they are shimmed and gluing. A couple of points to note here. The plastic trim rings were removed by carefully going around the inner edge with a flat blade screwdriver. Once all the old foam has been scraped off, I used Goof-Off to remove the last residue from the cones and dust caps. I used the correct black glue for the surround to cone join, and white glue for the surround to basket join. I already had two 8" surrounds that I got from Rick for some other Infinity's that I didn't end up refoaming, so I used these and ordered two more. The woofer surrounds laid flat on the edge and didn't need to be pegged, but I used pegs on the mids as the edges kept wanting to lift up.
Look at the cabinet bracing in these babies. Front to back and side to side above both woofer openings.
And here they are with the drivers installed.
I haven't done anything with the crossovers yet. They have a film cap already for the tweeter, I might get a film for the inline cap to the midranges, and maybe some new electrolytics for the midrange and woofer shunt caps.
Thanks to Tom over at myaudioaddiction, and to Rick Cobb for the surrounds.
Lee.
Lee.
