Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Thank you all for your assistance, sometimes things look different the next day and that seems to be the case for me here. Not that I'm sure this is right, but... looking again at this schematic, in the upper right corner are the plus and minus wires heading to the speaker which is where the destroyed cap is. there is a cap there in spot c117 that is listed as 22uf 50volt. having looked that up that seems like it might be a good fit. based on the little black plastic disc with 2 little metal tabs protruding from it I do believe this is an electro cap and not a ceramic one, as well as blurry picture I mentioned in original post. If someone would grab a look and see if that makes any sense that would be great. I think it also follows that the little yellow egg shape is a cap repeatedly seen across the schematic and would be the 0.1uf cap, which also gives some credibility that the 22uf 50v would live in that spot. Regardless a second set of eyes on this would be great also if this turns out to be correct is there a trusted brand I should look for when purchasing?
