Well, it`s more correct of me to say, im gonna use these speakers for both music and home cinema, as i dont have space for 2 different audio setups. What do you think about the Onkyo processor combined with this system?Also im curious to check out vinyl
Vinyl will be a whole new experience to me
Okey, so prefereably a good stereo preamp for the kappa 9`s? Any suggestions for a good budget preamp combined with a krell ksa 300s?The onkyo will be ok for surround but I wouldn't use it for two channel.
I use my epsilons for two channel only in the same room as my surround system but the surround system used different components and speakers.
I use iL 40's for fronts, iL 36 for the center and iL 10's for rears.
My epsilons are way to revealing for surround sound as were my kappa 9's that had even more detail in the semet tweeter, the iL speakers tweeters are naturally rolled off as compared to EMIT's, to me you can listen to the iL speakers in surround all day long and never get any listener fatigue, with the speakers with EMIT'S not so much as I don't think they were designed for home theater.
I like to see the different opinions from people, regarding usage of the speakers in different systems, all in all it will all depend on who`s ears are listening, yes?I have two EMIT-based home theaters set up (one in a dedicated theater, the other in the master bedroom) and I wouldn't agree about the fatigue experienced with EMITs. Now, to be fair, the only classic (i.e. rectangular) EMITs are in the Kappa 8s used as front left/right in the theater. Everything else, including centers, is EMIT-R. But Infinity did make at least four different EMIT-R based centers (Kappa Video, CS Video, Delta Center, Infinitesimal Center), so home theater was at least somewhat on their mind.
No, do not remove anything. Deoxit is nonconductive and won't harm anything (remember, it's designed for electronics). If you're concerned, put some masking tape over the vents in the back of the pots, and spray through the space around the shaft on the other side. This will prevent any overspray from soaking into the stuffing or onto the speaker cones.About the potentiometer\L-pad cleaning mentioned earlier in the thread, i was curious, do i have to desolder the pots\L-pads or disconnect anything when applying deoxit and cleaning these? I can safely spray these without damaging anything like resistors\caps or risk shortening any circuits in any way?![]()
That's because the center speaker is where most of the dialog comes from, human voices, a rectangular emit in the center would give you listener fatigue much faster than say a soft dome tweeter.I have two EMIT-based home theaters set up (one in a dedicated theater, the other in the master bedroom) and I wouldn't agree about the fatigue experienced with EMITs. Now, to be fair, the only classic (i.e. rectangular) EMITs are in the Kappa 8s used as front left/right in the theater. Everything else, including centers, is EMIT-R. But Infinity did make at least four different EMIT-R based centers (Kappa Video, CS Video, Delta Center, Infinitesimal Center), so home theater was at least somewhat on their mind.
I would wait for someone who owns a krell to reply and help you with choosing a good preamp to better match the sound of the krell amp to your k9's as for the IL they have a aluminum ceramic coated 1 inch dome tweeter that to my ears and compared to all the speakers that I own that have EMIT's in them they are rolled off and smooth sounding and designed for HT so you get less listener fatigue from watching hours of movies, I have epsilons and other speakers with EMIT'S in them and I would never use the speakers with EMIT's in them for HT unless you can match the electronics to curb the EMIT'sOkey, so prefereably a good stereo preamp for the kappa 9`s? Any suggestions for a good budget preamp combined with a krell ksa 300s?
So what you are saying is, the S-emits and emits are not very suitable for surround?
What is "iL"?![]()
Also, the Video/Center models came out after they had transitioned to EMIT-Rs on almost all models.That's because the center speaker is where most of the dialog comes from, human voices, a rectangular emit in the center would give you listener fatigue much faster than say a soft dome tweeter.
Im going to order some deoxit d5 then, and i will try to apply this directly to the pots\L-pads from the inside, and just cover up the crossover with something so the spray don`t dash all over it and it`s componentsNo, do not remove anything. Deoxit is nonconductive and won't harm anything (remember, it's designed for electronics). If you're concerned, put some masking tape over the vents in the back of the pots, and spray through the space around the shaft on the other side. This will prevent any overspray from soaking into the stuffing or onto the speaker cones.
I see your pointI would wait for someone who owns a krell to reply and help you with choosing a good preamp to better match the sound of the krell amp to your k9's as for the IL they have a aluminum ceramic coated 1 inch dome tweeter that to my ears and compared to all the speakers that I own that have EMIT's in them they are rolled off and smooth sounding and designed for HT so you get less listener fatigue from watching hours of movies, I have epsilons and other speakers with EMIT'S in them and I would never use the speakers with EMIT's in them for HT unless you can match the electronics to curb the EMIT's
But i will keep you all posted, though it will take some time to get there I was not aware of this, great to know, thank you for providing this infoAlso, the Video/Center models came out after they had transitioned to EMIT-Rs on almost all models.
ThanksCongratulations on your 9s. I’m a big fan. My room is small so I don’t use extended mode and it has plenty of bass for me. Most people on the forum know I have a very basic set up on mine. Parasound small preamp and carver amp setup. I have no harshness in the tweeters. Also the adjustments for midrange and tweeters on the back move in very small increments. You will be able to tell the differences if you get the volume high enough. I agree with okeetee u should use the 9s as music and if u have to use smaller satellites even for surround would be much better, the smaller speakers next to the 9s are my surround setup. Also if you can post pictures when u can we like pictures. I’ve attached a sample video as well. Let us know what u come up with.
View attachment 1470720 View attachment 1470719
But still, i couldn`t leave there without them, i had to buy them haha, so i took them, talked to a very good friend of mine and delivered them to him for restoration
The Kappa video has the same fluting as the Kappa 9, so they'll match, style-wise. I don't remember if you said what your room was like, but if you have the space, a single Kappa 6 might make a good center (it can be used horizontally if you rotate the tweeter). Kappa 5 would work as well, but they're relatively rare and usually overpriced when they come up for sale.I was not aware of this, great to know, thank you for providing this infoI really want to stick to the kappa classic series for my whole surround setup, if possible and if it sounds right
Want all spekers to match in looks, if you know what i mean, just love the looks of these cabinets with the wooding and details
This is exactly what my brothers did, they bought a pair of 6's each took one, and they're the center channel for each of them matched to Kappa 9 and kappa 7.1 respectively.The Kappa video has the same fluting as the Kappa 9, so they'll match, style-wise. I don't remember if you said what your room was like, but if you have the space, a single Kappa 6 might make a good center (it can be used horizontally if you rotate the tweeter). Kappa 5 would work as well, but they're relatively rare and usually overpriced when they come up for sale.
What i had in mind for my surround speakers up to this point, just to match the style of everything was:The Kappa video has the same fluting as the Kappa 9, so they'll match, style-wise. I don't remember if you said what your room was like, but if you have the space, a single Kappa 6 might make a good center (it can be used horizontally if you rotate the tweeter). Kappa 5 would work as well, but they're relatively rare and usually overpriced when they come up for sale.
How about a Aragon 8008 mk2? I just had someone contacting me and maybe willing to sell me, but i need to know if this also are capable of taking on the kappa 9`s.. And is this model of Aragon stable down to 1 Ohm?The Aragon 4004 is supposedly stable down to 1Ω and it's a popular amp to run Kappa 9s on.
