Worth CDN $85? No question, probably worth at least $150. I'd bring something I could test them with. Do you have an inverter for your car? And do you further have an amp or receiver that you can plug into the inverter to test the speakers (you'll be limited to about 120 watts total power consumption, NOT power output, but that should be fine for a test)? You can use your phone as a signal source.
Or does your car have an aftermarket stereo with a separate power amp? You can connect the Infinities directly to that amp. Or if the rear speakers in the car are accessible, you could unplug the connectors from those speakers and use some alligator clip leads and extensions and connect to the Infinities.
You can also try momentarily connecting a 1.5V battery to the speaker terminals using some extension leads. Listen for a click from each driver. I'd also push in the woofers near the center (to the left and right of the center cap) and make sure you don't feel any voice coil rub. They should move smoothly in and out. If you have a multimeter, bring it and test the resistance of each speaker. They should be fairly close (within a 1/2 ohm of each other). Should measure around 3-4 ohms.
