tonythemedia
Hi, my father-in-law recently passed away and he had an audio rack back in his closet full of high-end gear from the late 80's. One of the items is a Sony TA-N77ES Amplifier. He has the matching pre-amp, as well.
I attached it to a pair of Bose 901 speakers he had and have tried all day to get it working. I have attached an iPod with an RCA adapter to the variable input and set the volume very low. I have also tried the fixed input.
Thank You
Tony
- The unit powers on with the protection light on, then after 7 seconds the protection light turns off and I can hear at least one relay clicking.
- The stereo or mono light is working based on what I have the switch to set in the back.
- The meters are lit and both are moving.
- If I turn the attenuator knobs, the meters change accordingly.
- If I move the fixed/variable switch, I do hear a relay switching and the meters indicate no signal until I physically move the rca from one input to the other.
- I tested for continuity between the speaker outputs and the posts on the vertically mounted board and everything checked out.
- The heatsink on the right gets warm after a few minutes so I think the transistors are working.
- None of the capacitors that I can see look damaged, but I did not remove the black plastic housing labeled "audio capacitor".
Thank You
Tony
