i got that upgrade crossover from the ebay guy. it came nicely assembled with good instructions which required that i nevertheless get a little push in right direction from the ever patient, gracious and helpful paul c.
i spent weekend before last disassembling a pair of minimi i've had for god knows how long, sanding the white paint down, and repainting the cabs krylon hammertone bronze with the grilles in satin black.
i also completely disassembled and removed the old crossovers and reattached the new components to the old spring clips. i toyed with new binding posts too, but that was jiggier than i wanted to get.
i employed a set of replacement woofers i've had around for a while, the
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=290-370 4 ohm woofer. i asked the ebay guy to configure the x-over for the 4 ohm part, which only cost a buck or two....
it all went together well, even with the huge 4.7 250v (50v stock) tweeter cap and the much bulkier induction coil.
i have been using the speakers as fronts in my HT setup along with a JBL sub. our room is pretty small, so we are almost doing nearfield listening. a strength on these little jobbers is soundstaging, and that only improves with the upgrade. sound is more solid, and with 4 ohm woofs drawing more current, bass is stronger and tighter, though not deeper. they sound like a much bigger speaker and they form a pretty seamless blend with the woof.
it was fun for this extremely green DIY'er, and the results were nicer speakers, and several hours of placid absorption in a basically meaningless, though nevertheless satisfying task.
recommended!
