Toiler
Member
Hello all! I am Rob, up in Edmonton Canada. I am NOT a competent electronics technician, only a very basic knowledge guy who likes looking at videos on YouTube and likes vintage gear. I have a Pioneer SX-850 receiver that was fully serviced by a qualified tech a couple months back And working in proper order.
This past weekend I chose to install an Arylic Up2Stream Mini, to provide streaming from my smartphone via wifi. I had success (generally speaking). But there is a PROBLEM!
First, here’s what I did to install. I needed 5 volt, 1 amps to power the Arylic unit, so I used a little white, square Apple branded USB charger That I had sitting around. I connected one blade of that little cube shaped USB charger to the Pioneer SX-850 ground (with simple wire and solder) on the other blade to the switched line power (with a 1 amp glass fuse in between). I then plugged a USB cable from the charger to the Arylic Up2Stream mini. I connected (soldered directly) each of the so R and L, + and - speaker connections from the Arylic, to the Pioneer unit’s circular looking, rec/play input (the one that really now one EVER uses. inside the Pioneer unit, these rec/play connections are actually jumpEd across to the Tape 2 inputs with soldered wire connections that were done during the Pioneer’s original manufacturing.
Of not (possibly): I also replaced the original non-polarized cord with a new polarized cord. The original cord was 18 gauge and I replaced it with a 16 gauge cord. I believe I did ensure that this work was done correctly, ie line and common are connected into the Pioneer in the proper manner.
HERE’S THE PROBLEM: When I turn on power, I hear a fast but fairly quiet, ’clicking‘ or ‘ticking’ coming noise through the speakers (not a mechanical clicking like the relay switch or anything like that). Within about 10 or 15 seconds thereafter, that fast clicking reduces to a slower clicking. The change in the pace of the clicking (I am pretty certain), coincides perfectly with the initial ‘searching’ by the Arylic unit for a connection to wifi. As I mentioned, once connected to wifi, pace of the clicking slows dramatically. Of note, the clicking sound comes through the speakers NO MATTER WHAT INPUT I SELECT!
This situation is exceedingly annoying and very disappointing.
Direction on how to correct this issue would be greatly appreciated!
Here is a link to the Arylic Up2Stream Mini https://www.boomaudio.de/media/pdf/90/60/e6/Up2Stream_Mini_V3-0_200408.pdf
Maybe the one with an IEC mains inlet has been modified.
