Sansui — do the research and tune your budget to the model you want or can find. But try to avoid the ones whose caps are anchored with glue. Test whatever you are prospecting and be aware that Sansui spare parts are made of unobtainium — including some of the transistors used in later models. All that being said, nothing sounds like Sansui.
That is for vintage. So let's finish that canard! Now, if I had to start over again I'd go with chip amps ... that is a T-amp or whatever. But you do need efficient speakers, of which I have none. Thus I am using power thirsty but great sounding speakers, a giant Sansui and a tube preamp. With a TT, digi source, tuner, DAC and some transformers, my stack is the size a VW Type I! Someday I am going to have to move into a smaller space and shrink this down. Down to chip size!
CONCLUSION and just my opinion: ditch yer speakers and lineup some super efficient units. I had the same CDP (until it croaked) — dated but still very good and superb build quality. You can always hang a DAC out the back later.
NEXT: Do your research for a chip amp. You could do well to head over to DIY Paradise — talk to Yeo, the proprietor. He can guide you to something that this unique little company produces in Kuala Lumpur. Good support and they have some good people on their forums to help out. DIY P. is always searching for the best chips that produce good sound. Much of their stuff is surface mounted and they use some very good discrete stuff too like very carefully selected capacitors.
This will cost a bit of dosh, but the results could be much better than a lot more money will usually buy. The bottom line here is this: you will do this once and finally for some years to come. As I said, if I had to do all this audio jazz over again ... and I will ... it will be with the new tech. Look it up. See Elliott Sound Products for some no BS info. Mr Elliott has been around for decades and yet he is on top of the tech and is dead straight with the public and his clients. There are lot of good essays on his site.
