Upon even more reflection and a lil more sleep...
I am thinking I am "in over my head here."
Not that I think it would be "impossible" for me to take this on, but I know the reality is that the "time needed" is what I probably can't afford or do not have.
After the lack of time there is also, lack of experience, skills, equipment etc.
Soooooo...
Thinking I am down to either a new receiver/integrated etc.
or
Have this unit rebuilt/repaired professionally.
To make this more complicated, I HAVE to be cost conscious here yet make sure I end up with something I can live with (enjoy) for the long haul.
I have been on the hunt for a local tech and "may have found one."
I spilled my guts to him about ALL I have done to this poor poor receiver and his response was:
Hi Ben,
We appreciate you contacting us, especially for the opportunity to work on circa 77's receiver with enduring appeal.
Restoration of your vintage Realistic STA-2000 Receiver (non-Dolby model):
- All new parts, full CAP replacement, both sets of output transistors and relay, Parts only $230.
- Other parts electrical damaged (if any) from pins #4 & #5 short event, will need to advise.
- Work is slow at this time, a full refurb of this order typically runs, Labor only $200.
- Your receiver design is least labor intensive as the circuit boards are each easy access.
- With that said, the labor for this specific time frame and receiver is, Labor only $100 total.
We recommend replacing both sets of amp translators to keep the manufacture date code / lot code the same.
Keeping all the components of the same / from the same manufacture build is critical for match balance bias between the L/R channels.
They along with the new CAPs will all settle (burn in) in really nice together.
Consider after the refurbishment, that you are in effect purchasing both a NEW and VINTAGE unit.
My work flow plan / cost mitigation recommendation,
- 1st stage, order minimal parts, replace both transistor sets, parts $25 and labor $25.
- Test unit to exclude any pin #4 & #5 short event damage.
- Conditional no other issue then we advance to 2nd stage of refurbishment, ordering the CAPs & Relay.
- Finishing with full cap and relay replacement balance $280.
- Total part $230 + Total Labor $100, refurbished total $330.
Thank you,
Ken
A) I don't know this guy at all and have NO recommendations to go on..
B) It "sounds" (to me) like he knows what he is talking about and has a good "plan of attack."
But just curious, if anything in what he said would be problematic or a red flag for other more experienced people?
Not so much asking about his quoted price, as I figure I would be nearly a third of his cost to just get output transistors and a decent soldering station.
Any thoughts, opinions?
Ben
