QSilver
I've been working on an SX-V80 I picked up a month ago or so. Giving it a recap, replacing very worn trimmers and some resistors. I finished the job and powered it on for a test to find the left channel was very weak.
After a lot of probing, I've found that the signal remains strong all the way through the pre amp, volume control chips, op amps etc.... it's only when it gets to the final IC before being passed to the power amp section. This seemingly controls the "Simulated Stereo" feature and the subsonic feature. I have a good signal, equally comparable to the right channel, on Pin 20. The signal is still good on the Pin 20 side of R437.
On the other side of R437 and all the rest of the way to the pre amp out jacks, the signal is feeble and almost not even there....
I've tried changing R437, I've lifted R439, I've even disconnected the pre amp out jack cable from the board and nothing improves it. My next thought was to maybe consider bypassing the IC... I can get another one of these.... looks like its a TC9163N...
Just looking for some advice as I'm a bit stumped as to what to do next... I feel like I'm almost there but maybe I'm not seeing something....?
EDIT: It's probably worth noting, that the receiver had been worked on before, the Zener diodes that regulate the 16+/-VDC supplies for the logic controls looked stressed and one of them snapped when I tried to remove it (it had been refitted onto the underside of the board) I then found that there had been a burnt out resistor for that Zener which had been replaced with a 100R when it should have been 150R. I rectified this too. The voltages to the ICs and Microcomputer are at 17.5V+/- the Zeners I replaced the originals with were 16V zeners.
Everything else is working well. Just this left channel issue the seems to be centered around IC404....
