Cody AOC
So I been needing to replace the caps in my vintage receiver it has 55 caps and I found a site that has full kits of the caps to upgrade them with should I go with this site? http://www.audio-high-store.com/
If you don't want to source them yourself sure. It can be cheaper if you make a list and order them from mouser or digikey.
Go to google type in your model # recap audiokarma and see what comes up.
Without knowing what receiver you're talking about, what kinds of components this vendor is going to provide, and what the price is going to be, there's no way of knowing whether it's a good or bad deal.
If you can't find half of the stuff on Mouser, there's either something wrong with how you're looking, or you're trying to find component values that were common decades ago but which have since been superceded by close equivalents.
I have the list of all the caps but it's a pain finding them all and the 2 places you said I could get them mouser does not have half the caps I need and digikey does not have all of them either I thought anyway this would be the best way to get em but do you think it's a good place to get the caps that site I posted?
It shouldn't matter while I use audio electrolytic capacitors if the same if and voltage for the most part right and polar if thsts what it is I found all the caps on digikey that is for sure the ones?
so you should look for replacements with lowest leakage
I believe the manufacturers would provide a nice comprehensive list of what they have provided in the way of improvements in specs that make their audio caps better than their standard caps when used for audio purposes. We just don't have any of those folks posting here. The Sony STR-DA777ES an older totl surround receiver is full of Nichicon audio grade caps. Why would Sony use those if they didn't think they would be better for what they wanted to do?
I don't think I mentioned spec sheets, just manufacturers and then alluded to their folks. You may be totally correct in that Nichicon makes a cap and sleeves it 10 different ways to give it ten different preferred applications, IDK, but I'm sure those in the industry as buyer or sellers might have a clue.
There is something to it, we just do not have any idea what that is.
