Don -- If you will, I think it is best at this point to describe:
1. How EXACTLY is the power supply -- IN TOTAL -- any different -- IN ANY DETAIL --from that shown on the schematic?
2. Have you installed an inrush current limiter on this unit that is possibly undersized and is periodically caving under the higher current demand of this particular unit?
Also, if you pull all the output tubes, will the B+ stabilize? If not, that should help in getting to the bottom of things real quick.
Also, if I may, it is quite harmful to the output tubes to remove JUST the plate voltage by disconnecting the CT of the OPT in a pentode based design. Doing so leaves the screens to try and pass not only the current they normally draw, but also that which WAS being attracted to the plate. Without any plate voltage present then, the screens take the full brunt of the current flow within the tube, which can damage them quite quickly. Just some FYI!
Dave
Dave
