I've been meaning to build one of these for awhile. Good suggestion.As suggested if you can use or build a Dim Bulb tester with a switched power. Not just plug-in
Good idea- would a PWM work here? I think I have one of those in a drawer somewhere...I had a 120v fan on the Adcom and I used 600 ohms which dropped the fan voltage to about 75v. I added a bypass switch to the amp as well so if you are rocking the house you can run it full speed.
Answered my own question- a PWM does work. Not sure if it's the best solution, but it works.Good idea- would a PWM work here? I think I have one of those in a drawer somewhere...
Some of those power caps may have a bulged top. Side photos would be nice.![]()
Think I could unplug the fan altogether? I could put a thermometer in there and check- what's a reasonable max temp to shoot for?+1
The pro amps I use at home barely even get warm. And those are the convection cooled models. The ones that have fans always blow out cold air.
These things are meant to put out close to max power for hours at a time without self destructing. In anything from freezing to 90+ degree temps.
Great question but No clue. Regal cinema owned it prior to me so I'll never find out. As discussed next time I get over there I'll try to pull another unit and see what it has.I am wondering why 7 of them are SHM and 1 is KMH. Did one have to be replaced for some reason?
I am wondering why 7 of them are SMH and 1 is KMH. Did one have to be replaced for some reason?
Here you go- they look OK, I think?
View attachment 2408959 View attachment 2408961 View attachment 2408962
Bad power transformers usually have stink from over heating or burning out... sniff it a few times....
