No. The power switch goes between the gate and A2 side.Here is my proposed rendition for a Yamaha CA-610 II, before / after. Looks OK?
View attachment 3797699View attachment 3797700
Thanks for your response. I did notice the switch was connected to the A2 side on several of the diagrams floating around and I'm not getting why.No. The power switch goes between the gate and A2 side.
The BTA12-800BWRG is rated 12A continuous and 120A surge... Neither normal power consumption nor inrush current would likely come near.Better to use the part recommended in original post too, more current headroom.
Agreed.I usually connect the switch-resistor-gate array directly to the AC line, not through the transformer
Do you consider it a safety concern to keep the triac on the hot side? My understanding is it will work either way. If you go polarized don't you give up the option to reverse to reduce turntable hum?To avoid this, this amp is getting a new polarized power cord.
Switching on the neutral works in terms of functionality; so does a Chicago three-way, but you wouldn't want one in your house![]()
Agreed.
But US-market vintage gear generally has non-polarized plugs, making that connection a crapshoot, with gear as likely to be switched on the neutral as on the hot (as it should be), depending on the direction the plug was inserted.
In any event, it's best to diagnose and fix the grounding fault.
Another avoidance technique is to round-bin the idea of a triac and install a relay that will not create line/crossover noise, will not alter the AC incoming waveform, and will not expose the switch to any potential high load if the device fails.
