Here are some pics, starting with the amp, and then the pre amp. If these aren’t good enough quality, let me know and I can take more.
The filter can I used only covered C1 A-C, so there is a standalone cap for C1D (Cathode). Two wires (yellow and yellow-green striped) connect to the positive side of C1D, negative side is grounded to a grounding tab on the can (white wire).
Two ceramic caps associated with the center channel that are out of tolerance circled in red.
Part 1 of 3 of the pre-amp - two out of spec caps circled
Preamp 2 of 3
Orange electrolytic caps replaced last year - all ceramic caps in view tested outside of tolerance.
Preamp 3 of 3
Preamp 2 of 3
Preamp 3 of 3
