Issue with Pioneer SX 1280 on AFCI circuit
Please post the numbers on the transistors q1 and q2.
bout time we stopped assuming anything.
Pin 3 is .304mv engaged, 0mv disengaged
Pin 7 is .3V
C3 is 47/16
Pin 3 is low, which makes me think either the PA3004 isn't outputting enough voltage (it's drive circuit is dying) which means Q2 isn't switching in completely, or the base-emitter junction of Q2 is degraded and it's bias voltage is lower than it should be. I would pull Q2 and see if pin 3 gives a solid 0.7V.
The thing is that this 0.3v reading could be a meter artifact, as the circuit drops the relay immediately.
The only way that 0.3v is believable is if the unit continues with the relay PULLED IN.
Realistically 0.6 to 0.7v is needed before any current begins to flow in the transistor collector to emitter.
I'd thought he said the relay was pulling in for about 6 seconds; I'd think would be enough settling time for a DMM to take a solid reading. My thought was that if Q2 base-emitter junction was fried, it could have a lower bias voltage and be intermittently switching in and out. I'd be curious if he were to pull Q2 and measure pin 3 if he saw a steady reading or not.
If it continues to drop in and out, then maybe it would be easier to determine what part of the circuit is causing the protection.
Not sure if he was looking for voltages or the part numbers marked on the IC body? 2SA733 and 2SC1438 according to the schematics, but who knows if they might have been replaced in the past?
That is what they are. 2SA733 and SC1438.
Part Numbers. Those are Original Factory Transistors, go with ksa992 and ksc2690 if you have them.
A lot of my original assumptions have been ruled invalid by this news.
The "minty" status of either 1280 was no where near my standards for a minimal recap, no less a remanufacture, which is what I ASSumed was done.
Plus I swallowed the initial assumptions of the first posts and ran with them UNskeptically.
The six seconds was the delay between power on and the relay pulling in. AFTER which it would immediately drop out for another 6 seconds.
Mark,
Thank you. As always, I appreciate your expert advice and valuable time. I wish the restoration and repair standards of all technichians were to a level of yours and some of the great guys on this forum. I am in no way to the level of you guys and thats why I thought to take this unit to someone who knew more than i did. But alas it seems I was screwed over by a local repair shop in the Hudson Valley. $800 six weeks ago. The "original" condition of this receiver was such that I purchased it and had it driven by a friend of mine from Michigan to me in NY.
Your diagnosis now raises other concerns about workmanship, quality and what the heck else is wrong with this thing.
I would love to have your level of restoration performed on this receiver because I really want to keep it. In fact on both 1280's that I have, but I only have space to keep one. If you have any recommendations I appreciate it.
I have those transistors and I will change them out.
Thanks again.
So I just finished changing out the Q1 and Q2 transistor. Same issue still exists.
Q1 E12.83, C 0, B12.7; Q2 E0, C74.6, B0. So the only thing that changed was the voltage measurement of Q2 collector dropped .6V.
PA 3004 1 12.8, 3 0, 4 0, 5 0, 6 -7.3, 7 .3VA, 8 engaged 2 disengaged 5.4
Ok, some basic checks:
(I checked the thread first to see if we already did this, because I was getting a strong sense of deja-vu )
Is C1 (220uf 25v ) new or not?
1. temporarily ground the collector of Q2, to make sure the relay will pull in and STAY in.
2. Q1 gets disconnected, see if relay still cycles, leave disconnected for now.
3. ground pin 4 temporarily, see if cycling stops.
Yes, C1 is new 220/50. From the board markings it is installed correctly.
1. Did this and yes it does stay in.
2. Did this and yes it still cycles.
3. With Q1 removed, grounded pin 4 and it still cycles.
Thanks again Mark for the help with this.
1. proves the relay drive circuit is capable, including the pull in capacitor.
2. proves that there is no leakage or over current triggering input.
3. proves it's NOT the DC voltage sensing input on pin 4.
First, verify that AT pin 5 ground is zero ohms to the metal chassis.
Then verify that there is zero ohms from ground to the minus terminal(s) of the timing capacitor(s) C16 & C3.
Now, to contemplate what the PA3004 needs to operate:
pin 1 needs a stable +13 volts to operate.
pin 6 needs a stable -7 volts to operate, so D3 anode should stay at about -13v.
pin 5 needs to be grounded.
pin 4 stays grounded for now to simplify things
there is no pin 2, and pin 3 is an output, with a new transistor. The LAST resort will be to disconnect that transistor.
Pins 1, 4, 5 & 6 all should have a stable voltage and STAY stable
That leaves pin 8 which is the timing capacitor. Check the ENTIRE trace connected to pin 8
and the cap(s) for ANY indications of a short or any interference. To pin 7 especially, as well as D3 anode (that -13v point).
And pin 7 which is an AC voltage input.
I have reviewed the pin 7 readings in the thread, and think there needs to be a close examination here. The older posts have a slap-dash feeling.
That integrated circuit senses on it's pin 7 the AC voltage through a voltage divider (r10 1.8m, r9 680k, in > out = 27%) monitoring the pin 12 RED transformer wire that is supplying the raw speaker power (+/- 76 to +/- 65 V DC) for the LEFT channel.
it's a bit harder to figure out what makes it unhappy when compared to a transistor implemented protect circuit.
so I WANT AC voltage reading ( probably around 100 volts) of the board's pin 12. Then the PA3004's pin 7.
Then set the meter to read DC, and read pin 7 again.
On all these readings, watch them through several cycles of the relay, and see if there is any correlation between differences in readings to the cycling.
pin 1 needs a stable +13 volts to operate. 12.8VDC
pin 6 needs a stable -7 volts to operate, so D3 anode should stay at about -13v. -7.3VDC and -13VDC
and the cap(s) for ANY indications of a short or any interference. To pin 7 especially, as well as D3 anode (that -13v point). Did this and looks good. Pulled caps and re-installed to verify solder connection. See pic. Checked D3, and re-soldered as well.
On all these readings, watch them through several cycles of the relay, and see if there is any correlation between differences in readings to the cycling.[/QUOTE]
Board Pin 12 56.3VAC steady thru cycles.
PA3004 Pin 7 .3VAC steady thru cycles.
PA3004 Pin 7 .03VDC steady thru cycles.
mark will figure this out . i am useless at voltage dividers .
ac must be more than expected going off the ac after rectification . so pin 7 pa3004 should be a bit high rather than rather low .
D3 anode is the odd thing here .
have you got 2 multi-meters ? just a thought ..
p.s sorry to butt in here mark . will leave you to it and follow . i am busy doing a 70th birthday at the moment . well its sleep time now ..16 channels to tune in tomorrow .
resolder the chip except desolder pin 7 and stand up the pin so it is disconnected from the foil.
Then check operation, pay attention to if the 6 second delay even happens and the relay tries to pull in.
Remeasure the voltages, and for the divider bridge measure the foil that's isolated from pin 7.
It looks right now like pin 7 has a problem, pulling too much current from the divider.
You could check the resistors in the divider bridge.
R10 is 1.8 meg ohms, R9 is 680k ohms.
You can also set your meter on AC amps and measure the current being pulled from the divider bridge.
connect the red dmm probe to the foil connecting r9 and r10, the black probe to pin 7.
Just curious....when you try it at home vs. away, is there other stuff connected to the receiver at home but not when trying it away?
