This will be taller but should work.Thanks so much for getting back with me David. Parasound no longer sells parts and the person people mentioned, Tony, doesn't have a valid email. I ordered a miniature toggle switch from Mouser but it wouldn't fit. I was unsure if I was to solder the middle together and the bottom together. It sounds like I'm supposed to put a jumper from the bottom pins to the middle pins. I just checked continuity from middle to bottom with the switch pushed to the other side. I'm going to put the jumpers in tomorrow and let you know. Thanks for the help.
