Issues with start and stop functionality on my Denon DP-47F
i have the same problem with mine denon dp-35f ( opened separate thread about it)....while starting it is blinking at 33, and when i press 45 and go back to 33 it locks speed?
everything else works fine...
I haven't had a chance to work on it yet, if I figure out a fix for it I'll post an update about it in this thread! The advice from HiFi Poland seems pretty sound.
i have the same problem with mine denon dp-35f ( opened separate thread about it)....while starting it is blinking at 33, and when i press 45 and go back to 33 it locks speed? if i use carbon brush while blinking at 33, it lock speed, it looks like that resistance helps to lock speed...very strange...
i think i found the problem! i opened up mine tt and find one small black capacitors near trim pots went bust...it is marked as C202 and it literally have a hole on top...
did anyone know the right spec? since it's an older one, i suppose i can change with some newer with higher voltage and higher temp spec? any recommendations?
there's a seller on the auction site who peddles recap kits for Denon TT's; I did my DP-37 a while back- it took about two hours and was not difficult.
