I'm liking your idea of adding the N8000 crossover with the extra pair of tweeters I have (077's not 2405's) and hiding them (crossovers) inside the cabinet. As I won't be doing the actual wiring and mounting I will be asking my tech guy to do this for me for so I was wondering where i might get a picture or wiring diagram that I can hand to my guy. My tech guy is in the process of cleaning up and recapping the original crossover right now (3131A) and I would like to find a set of N8000's and get them to him ASAP. I will also need to find a new set of foilcals and L-Pads which I don't mind mounting on the front where they would normally be. Any help on a diagram or a picture would be appreciated. Thanks a lot for all the feedback above.I wouldn't bother with building the lenses unless you want to do the wood work, they have a specific angle and spacing and cutout to do the right job at the right frequencies. There are already good reproductions at Kenrick and the price isn't terrible considering the time and effort to reproduce them on your own.
As for veneer, SAEMAN or the Rick in Kenrick veneered many large format JBL Monitors in Rosewood which were just spectacular.
you can easily upgrade the 4331a to a 4333 by adding a separate crossover for an 077 or less expensive 2405 tweeter, the crossover to use is the N7000, or you can add something similar (just the circuitry) into the existing crossover and be sure to add the crossover L-Pad for adjustment of output. you may then have to get a new foilcal as the existing foilcal would cover where the new L-pad normally would go. Or you could just position the new L-pad past where the current foilcal edge ends.
You could just have him build these crossovers: http://www.firstwatt.com/pdf/art_l300.pdf
Your darn right, I would love to have those crossovers. I read Nelsons article as well and if he's happy with his L-300's I'm sure I would be in heaven. I got to admit though I've been using my Jubals while the cabinets are getting done and they are a damn fine little speaker in their own right. I think I'll just keep them as a backup set or wire them as my upstairs speakers as my wife doesn't mind the look of the Jubals (little glass top end tables).You could just have him build these crossovers: http://www.firstwatt.com/pdf/art_l300.pdf
Yes I'm sure Nelson Pass has amplifiers we can only dream of at his disposal. I'm driving my speakers with a Bryston 4B SST and it's more than ample right now. I have a second Bryston 4BST that I can use as well when it comes back from service at Bryston in a couple of weeks. Two 4B's would do the job pretty good I would think running them as two mono amplifiers.Here is the JBL 4331B from the JBL Professional site under Support, then Service, or directly under www.jblproservice.com, then "Exploded Views", then Studio Series. Direct link to tech sheet:
http://www.jblproservice.com/pdf/Studio Monitor Series/4331B.pdf
Direct link to 3131A crossover network:
http://www.jblproservice.com/pdf/Network Schematics/3131A Network.pdf
Here's the corresponding info for the 4333B:
http://www.jblproservice.com/pdf/Studio Monitor Series/4333B.pdf
Direct link to 3133A crossover network:
http://www.jblproservice.com/pdf/Network Schematics/3133A Network.pdf
Here is the 3106 pro network which is identical to the N8000 for use with the LE85/2420 mid compression driver and 075/077/2405
http://www.jblproservice.com/pdf/Network Schematics/3106 Network.pdf
Personally, I would create the HF section (2405) section of the 3133A by adding the 1.0uf cap and moving the 1.5mf cap behind the 0.16mh inductor of the 3106. This creates the 3 element (2 caps and 1 inductor) 18db/decade crossover point for the 077 instead of the 2 element (1 cap and 1 inductor) 12db/decade crossover point of the N8000. You can see the LF (really MF) section of the N8000 is added on to the MF section of the 3131A so that comprises the MF section of the 3133A. That way, you don't have to have the outboard box of the N8000 and all the wiring, but add it directly to the 3131A box.
that would be another great option. Interesting choices with the 077. However, this assumes, as stated in the article, driving the speakers to less than maximum volume, even though he states he uses up to a 600 watt amp.
Yes, I did the same thing and just got them a week ago. They look and function quite well, now I just need to build some grilles for these babies although they won't be on the speakers very muchI bought the Kendrick lenses and am very pleased with them for $130. It's a no brainer.
Those look fantastic, you did a great job. I'm very anxious to get my 4331's up and running again as they sound incredible(in my opinion anyway). Just need to get them all beautiful againI need grills on my 4343b"s as well. For under $1000..... we did well.View attachment 653838
Yes I'm going to keep an eye out for a pair of proper crossovers but in the meantime I don't want to do anything to them that would ultimately detract their resale value. I plan on keeping them but you never know and I think keeping them as stock as possible is always a good idea.Take your time. It's worth it in the end. I even used new screws, although I had to paint them. If you can upgrade with the prism tweeter.....you won't be sorry!
