^^^ THIS. Can't emphasize that enough.
The actual crossovers themselves, can ALSO BE the EQ circuit, in some cases. Changes in the damping (the shape of the rolloff curve), and even slight gaps or overlaps in the crossover frequency (which JBL did a LOT) can change the electrical response curve to the drivers drastically, and make the crossover extremely "non-textbook" and hard to duplicate without some sophisticated DSP or the like.
I have personally done these tricks, with damping and overlap/underlap, to great results in speakers I've designed. Got a midrange with a rising response with frequency (the high end is higher output than the low end)? Use a high-Q highpass on the bottom (to add some energy in the midrange lower end), and a very low-Q lowpass on the top (to reduce the energy at the top end), overlap the midrange crossover frequency slightly with the woofer (so they "add" more), and under-lap the midrange crossover frequency with the tweeter (to "subtract" a bit). Turned out very well... and technically, no EQ involved. The circuit is no more complicated than a normal textbook crossover, but it does some things significantly differently!!
Regards,
Gordon.
Regards,
Gordon.
