FireGuruMN
I have another thread in the "Lansing Legacy" about these speakers also:
https://audiokarma.org/forums/index.php?threads/jbl-4435-bucket-list-countdown.901225/
That thread talks about positioning and replacing the diaphragms in the horns. The executive summary:
Position them wherever they will fit.
Replace the factory diaphragms with Radians.
I've been on a kick to replace capacitors in all my speakers. I was having an internal debate about whether these 4435's needed new caps or not. Since you are reading this I obviously decided they do need replacing. What drove me over the edge was that the speakers did not sound the same. I cleaned, positioned, polished, adjusted and measured everything I could with the exception of the components on the crossover.
Seems like COVID is starting to limit supplies of some things like Solen capacitors (France) and Mills resistors (Mexico I think). So after waiting for backorders and other delays I eventually acquired everything I need:
(quantity per speaker)
Resistors (you really do not need to replace resistors in most cases. All my removed ones were just fine It's a guy thing:
Qty 4 of 62 ohm resistors. 71-RS10-62 (mouser). Kind of nice because they are the same size as the originals. Bigger than Mills, black, cheaper. Hard to find 62 ohm values.
Qty 1 of 5 ohm resistor. Original was 5.1. 71-RS0105R000FE73 (mouser)
Qty 1 of 10 ohm resistor. 71-MRA-1210R00FE12 (mouser)
Qty 1 of 20 ohm resistor. 71-MRA-1220R00FE12 (mouser)
Capacitors:
Qty 2 of 15uf capacitor. I like Solens. Live your own life. 027-576 Solen 15uF 400V Polypropylene Capacitor (parts express)
Qty 1 of 12uf capacitor. 027-572 Solen 12uF 400V Polypropylene Capacitor (parts express)
Qty 1 of 2.2uf capacitor. Original was 2.5 but that is not a common value or they were out of stock. With a 0.15 bypass it is close enough. 027-558 Solen 2.2uF 400V Polypropylene Capacitor
Note: There is also a 20uf capacitor with a bypass that is only in the circuit when you switch to an external crossover. I modified my speakers (read on) so that capacitor was never in the circuit. I think it was mostly just a safety in case someone tried to run full power low frequencies through the horns. 20uf is not a sensible value to have at that position in the circuit when it comes to crossover frequencies..
Bypass Capacitors. Get whatever kind you want. It's a personal thing. Originals are all 0.01uf. I got 0.10 and 0.15 for my own reasons and what I had laying around. It really is a tiny value compared to the main capacitor. Blue on Black, Smoke on Fire, Whisper on a Scream (Great song). If you have super nice main capacitors do you even need bypasses. I'm not getting into that here.
Qty 1 of 027-127 Audyn Cap Plus 0.15uF 1200V Double Layer MKP Metalized Polypropylene Foil Crossover Capacitor (I used this on the tweeter, I ordered it for LPM100's until I realized how huge it was. Always check dimensions on caps)
Qty 2 of 027-710 Audiocap PPT Theta 0.10uF 600V Film/Foil Capacitor.
Inductors are just fine how they are. If you want to get air core or something else to prove your manliness go ahead but you will probably need to build a separate board or something to mount them.
Binding Posts. Whatever you want. Or just leave the originals in place. I just used two posts per speaker but if you ever want to bi-amp them you will need 4 posts.
There is some Easter Bunny connection further on. But it's mostly just to make the post title more interesting than just another 4435 recap. Really, if that was not in the title would have gotten this far?
Continued. . .
Capacitors:
Continued. . .
