Great! Thank you Gordon!. I'll look into the 2405 tweeters, As far as corssover, this may be a stupid question, but will the 130A work well with either N7000 or N8000 crossover?
You will want the original crossover and the 175 mid horn, as well as the 130A. It will wind up being a 3-way.
You'll want to wire it up as follows:
Use the N7000/N8000 input, as the speaker system input of the whole speaker. Run the HF output of the N7000/N800 to the 2405 tweeter. Run the LF output of the N7000, to the input of the original N1200 crossover. Leave the output of the N1200 as-is (LF to the 130A, HF to the 175 horn).
This will allow the new tweeter to produce the range above 8000Hz, while the 175 will do from about 1200Hz to 8000 Hz, and the 130A will do everything below 1200Hz. You will also be able to adjust both the level of the 175 (midrange) and the 2405 (treble), to fine-tune the balance of the speaker.
As for placement- it looks like there is room, to put the 2405 just below the 175. Just use the appropriate size hole saw to make a hole for mounting. Or, if you don't want to modify the baffle- the 2405 can be hung from brackets, in the mouth of the horn, just below the woofer. That's been done in many cases. It doesn't necessarily need to be mounted in a baffle- it will work fine, just hanging from brackets.
Or, you can do as some others have- make a custom mounting housing, and set the 2405 on top of the cabinets. That can look really cool, if it's done well...
Regards,
Gordon.
