Problem I had with running things that way- N1200, then N8000- was that by the time one turned down the midrange horn enough on the factory N1200 controls, to match the woofer- the tweeter was too attenuated, even turned all the way up.
If, as you say, you put a separate L-pad in series with the horn- then, you don't have to attenuate the N1200 HF section. That should solve that problem. But, without a separate L-pad for the horn, after the N8000- that setup never worked well for me.
Regards,
Gordon.
