I've been checking the heatsink periodically. According to others in the Accurian thread, it's only an issue if you crank it. I don't rock the house with these, plus they are surprisingly efficient. The Control 1 tech sheet says 90 dB, and that seems to be the case.Hey, Zilch, these Control line speakers are (nominally) rated 4 ohms. Isn't the Accurian notorious for failure when driving lower impedance loads? Seen any smoke yet?
Control SB5 doesn't reach all that low, either, but the RTA says I'm getting a strong 40 Hz in-room with the Accurian amp. I should do nearfield measurements to verify.... :yes:
