Ok, from looking at those 2 schematics above, it looks like mine are the L26A version (because mine have the LE25-4 tweeters). And looking at those other 2 bottom links, I am still not seeing anything as far as referring to which came first, "Model L26" or "Decade L26". They both still say "Decade" in the titles...... Someone please -Tell- me which came first, instead of sending me to another page. Thanks. That is all I ask, and please forgive my incompetence![]()
Could be an improper re-surround of the woofer is the culprit. Do you have photos? Does it do it all the time or only at high volume? You could try rotating the woofer 180º (turn the cabinet upside down to test) but that's a wing and a prayer repair. If it's not irreparably damaged from playing like that, you could have the surround replaced and the voice-coil aligned properly.I immediately noticed a rattle through the woofer of one of the speakers. Help! What does this mean. Was I taken advantage of on this deal. Any suggestions on a low cost fix for a novice?
If you had to decide between the L26 and Dynaco A25 which would you choose? and why?
