GD70
Lunatic Member
Those look great!I built a basic wheeled plinth under each of mine to favour my poor aching back ...
On a slightly different direction - - When I was Re-working my heathkit AS101s (Altec valencias), my guru suggested using RTV adhesive
to glue a layer of porcelain tiles and Granite tiles to the bottom and back of each cabinet. The resulting cabinets got heavier,
but also have a lot harder punch than they did before. Later on I laid an 18 x 18 granite tile on top and got a bit more punch.
(that one is not glued down - just has a layer of Gorilla Glue Duct tape stuck to the bottom of the tile - really!)
I no longer have my L200s - but I've wondered if such a change would get more punch to the JBLs - Mine had 2234 woofers
(same as the 2235 woofers but without the mass-rings - so slightly less weight and a bit faster punch).
The smaller 12 x 12 granite tiles would fit just inside the existing plinth and not be visible on the bottom -
someone would need to measure the ID of the plinths to see how large you could go in that space.
If these were in the family room, I'd go this route for sure, but furniture dollies will be fine in the cave.
Interesting results with the added weight on top of the cabs.
Glenn
(Humor)
