This was somewhat popular in the 80's in Europe - packing a bass reflex port with straws or other partial air passing material (socks, fiberglass, polyfill). It converts the bass reflex design with the typical resonance peak, sometimes +3db bump in the low bass to an aperiodic type vent, a resistive vent if you will which usually brings down the bump and sometimes extends the LF response at the expense of efficiency. The impedence peak will usually move to a double bump IIRC.
Works for some speakers, Zilch famously plugged ports entirely with the Zilchplugstm on some JBL speakers (original L100, L200 type cabinets, and some large single woofer cabinets with more than one vent) converting them to an acoustic suspension design.
It all depends on what you're looking for and JBL mostly designs for highest efficiency in a direct radiator design, hence the bass reflex port rather than acoustic suspension. Very few have used a resistive port (Dynaco, Dynaudio) and to some extent the IMF Transmission lines and Fried resistive lines.
Socks to hold the straws work ok but look goofy, nylons might be less obtrusive. On the L100T pictured, the port though is in back. The 2214H woofer is pretty darn good though in the L100T-T3 type cabinets. I have less experience with the L80T.
