Low Frequency Loudspeaker (Model 2245H)
The use of a 460 mm (18 in) low frequency loudspeaker in a 250 liter (9 ft3) ported enclosure provides accurate reproduction, and high power handling capacity extending to very low frequencies, with excellent sensitivity. The loud- speaker’s motor assembly consists of a 100 mm (4 in) diameter voice coil, fabricated of edgewound copper ribbon wire, operating in a 1.22 tesla (12,200 gauss) magnetic field. The 9.1 kg (20 lb) magnetic assembly incorporates JBL’s new symmetrical field geometry (SFG) design which, along with a Flux Stabilizing Ring around the pole piece, significantly reduces second harmonic distortion and provides accurate low frequency reproduction.The suspension is carefully designed to control the voice-coil motion, ensuring tighter transient characteristics with complete freedom from dynamic instabilities. A compliant cone termination (the surround) allows long excursions and, along with the specially coated cone, damps spurious reflections traveling within the cone material.
The 2245 has a listed frequency range of 20 Hz to 2 kHz
System Frequency Response Sine Wave, on-axis: 32 Hz—20kHz +3, -6 dB
