Heres a thread I found from 09 about these; Jensen System B
http://www.audiokarma.org/forums/showthread.php?t=213023
They are complete and total JUNK... As a favor to you, I will let you send them to me, along with any other System B or C's you find
Refoam them carefully (order the correct foam, dont use a generic)
Unless you see one that looks bad, dont bother with the caps, unless you REALLY want to go into it. They are a rare type of film cap and mostly overkill in quality.
All I had to do was repair a couple popped solder points, refoam, and enjoy.
The advice about the screws is dead on, be careful, and patient. the molded foam/plastic is fragile.
I have toyed with relaminating them and swapping out the connectors which in my opinion seem like the one area that didnt jive with the rest. Simple small wire connectors on a pair of speakers attempting to compete at the very top of the consumer market.
Regardless, refoam them, check the board for popped solder points as that was the only problem my xovers had, and enjoy.
And if you hate 'em.. By all means, I'll pay the shipping :yes:
