91rtstealth
Right now you have TWO, SEPARATE, FATAL problems in the receiver's power supply. Not leaking crud shorting things out.
Either problem is capable of causing irreversible damage elsewhere in the receiver all on it's own when powered up.
NEITHER problem is a quick fix - or I would have guided you to it.
diodes let current flow one way only - establishing a polarity, shorted diodes let current flow both ways - which kills electrolytic caps because reversing their polarity turns the cap into a short circuit - heating it up instantly.
The 107 board has enough slack on the wires to get at the bottom, the 4 other boards come completely out - most of the work on receivers is done using slack in the wiring to get at the boards for work. Having removable boards is both a luxury and a pita because of the connectors and having to clean them.
The 100v caps WILL HAVE 100 on them instead or 25.
The engine computer caps you speak of could have shorted out and brought everything down, even going as far as popping like a firecracker.
SO can these leaking caps, and the "leakers" were leaking rather than exploding. There is serious damage internally in them, and with ALL THREE on the same circuit showing damage at the same time, it means they are a symptom, not a cause. Shorted diodes d5 and or d6 are the most likely cause, and the capacitor damage will not go away or get better, or even limp along after the diodes are fixed. Chances are they have burned their foil plates together internally - vaporizing the foil connections as the damage creeps along the capacitors toilet paper roll type structure like a cigarette burning as the power is reapplied.
I've used diodes hundreds of times when I used to install car audio, video, and remote starters and all of that jazz...I didn't realize that if they burnt out they let electricity flow in both directions....that could be a real pain in the arse..haha..
so is there a way I can check diodes d5 and d6 with a meter?
also...where should I be weary of being electricuted..haha..i mean, I have had this unit unplugged for a few days...but I know capacitors store electricity..so i'm sure those 4 big ones could zap me, correct? i'm more familar with DC where you are less likely to be electricuted...what should I stay away from in the receiver?
but rather ah hah!! - that's what he was yammering on and on about...
