I really wanted to try out the JVC today, so I worked my butt off and I took 45 minutes this afternoon to give it a try. First, before I hooked any speakers or cd player to the amp I plugged it into the wall and turned it on, after a couple of seconds I heard the relay click but it did not look like any meters lit up. So I turned it off and hooked up my test speakers and an old sony cd player that I use to test with. Turned everything on and put in a cd, when the cd counter was at ten seconds I slowly turned up the volume and heard all kinds of crackling and static and only the right channel was working, but after fooling around with the balance control and the volume control the left channel kicked in and all the static and crackling went away.
It sounded really good, I played with pretty low volume for about 30 minutes and for the last 15 minutes pretty darn loud. The amp didn't get hot just a little warm, has really good power and sounds great, cant wait to try it with some better speakers than my test speakers. She is a dirty old girl so after a good cleaning she should perform and look a lot better. Not 100% sure if the meter lights are burned out as it was very bright in the room, I will be able to tell for sure later in the day when the room darkens. So far everything seems to be sounding good though so I am one happy camper.
