Hi,
I have a strange problem with Kappa 8A. When I listen at low volume, the Polygraph remains silent for a long time, it may take an hour before the sound starts to come out. The bigger the volume, the faster the element starts to work.
If I increase the volume considerably, the sound can be heard almost immediately (a small bang is heard).
If I listen at a low volume after this, the sound starts to fade from Polygraph and disappears after a while if the volume is not turned up.
I cleaned the pots but it had no effect on the problem. The elements are serviced.
In addition, both speakers have a really big damping in the +-4khz range and the phase sounds somehow strange. Sometimes they sound muffled, but sometimes they sounds amazing good and perfect.
Can you tell if the problem is faulty capacitors?
Has anyone changed the capacitors to the original ones, do you have a list of the components?
