Nikkoholic
Can I ask how you were able to remove the bottom section of your cabinets? I'll be needing to replace the cabinet bases on mine but didn't see the fasteners where the two section meet? Maybe mine are set up differently.
When you remove the Woofer and push the insulation out of the way you can see down into the crossover area. At the top of the opening on the tall speaker section (not the bottom crossover section) you will see 6 phillips screws around the perimeter or lip that forms the rectangular opening. Remove these and GENTLY bump the lower section. Mine have a black material that spaces the upper and lower section of the box. This black material has a bit of glue on it. It broke away pretty clean but I'd excercise caution to keep it in tack. All the wires are long enough to turn the crossover section at 90 degrees when disassembled. Also lay the speaker on its back prior to removing these screws!!
Hope this helps.
Hope this helps.
